ref - https://sweetalert2.github.io/
#angular2+
import { UsersApiService } from 'users-service';
import Swal, { SweetAlertOptions } from 'sweetalert2';
export class UsersOverviewComponent {
//in the following example, using ng2-smart-table, passing the grid row data to this function
constructor(private usersService: UsersApiService) {}
contextReset(rowData) {
//dialog options
let sao: SweetAlertOptions = {
title: "Warning!",
text: "You will delete the user : " + rowData.UserName,
showCancelButton: true,
cancelButtonText: "nah",
confirmButtonText: "yeah",
type: "question",
focusConfirm: true,
showLoaderOnConfirm: true
//dialog confirm promise (when showLoaderOnConfirm, this required otherwise doesnt show the indicator) - https://sweetalert2.github.io/#configuration
sao.preConfirm = () => {
//server activity
return this.resetUserPassword(rowData.UserName, rowData.Email);
//show the dialog
Swal.fire(sao)
.then((result) => {
if (result.value) {
if (result.value == "success"){ //user press yes - result.value returned by server activity
Swal.fire(SwalHelper.showConfirmation({ title: "Process completed", typeDlg: "success", body: "Email sent to user with futher instructions.", btnText: "οκ" }));
else { //HttpErrorResponse error throw by originated promise (aka server activity)
Swal.fire(SwalHelper.showConfirmation({ title: "Error!", typeDlg: "error", body: "Activity is not made", btnText: "οκ" }));
} else if (result.dismiss) { //user press no
Swal.fire(SwalHelper.showConfirmation({ title: "User press cancel button", typeDlg: "info", body: "Aborted by the user", btnText: "οκ" }));
resetUserPassword(username: string, email: string) {
var user = new UserRecoverRequest();
user.Username = username;
user.Email = email;
//https://stackoverflow.com/a/38932716 - return error to preConfirm promise, otherwise identified as good response
return this.usersService.recoverUserRequest(user).toPromise().catch((err) => {
return err;
//in users-service.ts we have
import { Injectable } from '@angular/core';
import { environment } from 'src/environments/environment';
import { HttpClient } from '@angular/common/http';
@Injectable()
export class UsersApiService {
apiEndPoint = environment.apiEndPoint;
/*create = (user: User) => this.http.post(this.apiEndPoint+'/PostUser', user);
get = (id: string) => this.http.get(User,`${this.apiEndPoint}/GetUserByID/${id}`);
search = (body:any) => this.http.post(`${this.apiEndPoint}/GetUsers`, body);
update = (user: User) => this.http.post(this.apiEndPoint+'/UpdateUser', user);*/
recoverUserRequest = (userRecoverRequest: UserRecoverRequest) => this.http.post(this.apiEndPoint + '/RecoverUser', userRecoverRequest);
export class UserRecoverRequest {
Username: string;
Email: string;
//spare swal-helper.ts
import { SweetAlertOptions, SweetAlertType } from "sweetalert2";
export class SwalHelper {
public static showConfirmation(options: {
title: string;
body: string;
btnText: string;
typeDlg: SweetAlertType;
}): SweetAlertOptions {
return {
title: options.title,
text: options.body,
showCancelButton: false,
confirmButtonText: options.btnText,
type: options.typeDlg,
customClass: {
confirmButton: 'btn btn-success',
cancelButton: 'btn btn-danger',
#angular2+
