Create and share Visual Studio color schemes
https://studiostyl.es/schemes/son-of-obsidian
tip : import it through > Tools -> Import And Export Settings...
Comment / Uncomment
Keyboard accelerators are configurable. You can find out which keyboard accelerators are bound to a command in Tools -> Options on the Environment -> Keyboard page.
These commands are named Edit.CommentSelection and Edit.UncommentSelection.
Comment / Uncomment
//visual studio 2012 - son-of-obsidian + comment/uncomment + consolas 12pt
<UserSettings>
<ApplicationIdentity version="11.0"/>
<ToolsOptions>
<ToolsOptionsCategory name="Environment" RegisteredName="Environment"/>
</ToolsOptions>
<Category name="Environment_Group" RegisteredName="Environment_Group">
<Category name="Environment_KeyBindings" Category="{F09035F1-80D2-4312-8EC4-4D354A4BCB4C}" Package="{DA9FB551-C724-11d0-AE1F-00A0C90FFFC3}" RegisteredName="Environment_KeyBindings" PackageName="Visual Studio Environment Package">
<Version>11.0.0.0</Version>
<KeyboardShortcuts>
<ScopeDefinitions>
<Scope Name="Team Explorer" ID="{7AA20502-9463-47B7-BF43-341BAF51157C}"/>
<Scope Name="VC Dialog Editor" ID="{543E0C02-8C85-4E43-933A-5EF320E3431F}"/>
<Scope Name="XML (Text) Editor" ID="{FA3CD31E-987B-443A-9B81-186104E8DAC1}"/>
<Scope Name="Text Editor" ID="{8B382828-6202-11D1-8870-0000F87579D2}"/>
<Scope Name="Work Item Results View" ID="{7026002D-01F6-44E7-95CF-A896C00DA3F8}"/>
<Scope Name="ADO.NET Entity Data Model Designer" ID="{C99AEA30-8E36-4515-B76F-496F5A48A6AA}"/>
<Scope Name="Solution Explorer" ID="{3AE79031-E1BC-11D0-8F78-00A0C9110057}"/>
<Scope Name="Query Designer" ID="{B2C40B32-3A37-4CA9-97B9-FA44248B69FF}"/>
<Scope Name="WebBrowser" ID="{E8B06F41-6D01-11D2-AA7D-00C04F990343}"/>
<Scope Name="Graphics Designers" ID="{58961B49-13E0-48C0-9258-13CBC4D40279}"/>
<Scope Name="AppManifestDesigner" ID="{4D47164B-07B6-4A52-A855-728D6A2E2AA3}"/>
<Scope Name="DataSet Editor" ID="{B334A759-F450-40A5-BE2A-65937BCD5415}"/>
<Scope Name="XAML UI Designer" ID="{E9B8485C-1217-4277-9ED6-C825A5AC1968}"/>
<Scope Name="Graph Document Editor" ID="{295A0962-5A59-4F4F-9E12-6BC670C15C3B}"/>
<Scope Name="F# Interactive" ID="{DEE22B65-9761-4A26-8FB2-759B971D6DFC}"/>
<Scope Name="View Designer" ID="{B968E165-98E0-41F0-8FBE-A8ED1D246A90}"/>
<Scope Name="XAML Editor" ID="{A4F9FF65-A78C-4650-866D-5069CC4127CF}"/>
<Scope Name="Microsoft SQL Server Data Tools, Table Designer" ID="{2366CF66-2394-4701-AFCA-37ED7FD41648}"/>
<Scope Name="Global" ID="{5EFC7975-14BC-11CF-9B2B-00AA00573819}"/>
<Scope Name="Class Diagram" ID="{59B0B277-7DDF-4E36-A3ED-02DAC5B9E2FA}"/>
<Scope Name="UML Activity Diagram" ID="{950C3878-B510-4BC5-9051-42798A870364}"/>
<Scope Name="Work Item Query View" ID="{B6303490-B828-410C-9216-AE727D0E282D}"/>
<Scope Name="Team Foundation Build Detail Editor" ID="{86306A97-84F2-4F5A-889B-1318501AEB5F}"/>
<Scope Name="CSS Source Editor" ID="{A764E89A-518D-11D2-9A89-00C04F79EFC3}"/>
<Scope Name="Database Designer" ID="{CFF78A9B-78A3-45A3-9142-0267AFC261FA}"/>
<Scope Name="Work Item Editor" ID="{40A91D9D-8076-4D28-87C5-5AF9F0ACFE0F}"/>
<Scope Name="Sequence Diagram" ID="{5028BC9F-844B-4C51-A624-0005945D14AE}"/>
<Scope Name="Graphics Debugger" ID="{D27456A1-9094-4CDE-BADA-82994ED560D8}"/>
<Scope Name="VC String Editor" ID="{58442DA9-10DA-4AA9-A2AF-96E4D481379B}"/>
<Scope Name="Merge Editor Window" ID="{9A9A8AAA-ACD2-4DB6-BD81-8D64176C52B6}"/>
<Scope Name="Settings Designer" ID="{515231AD-C9DC-4AA3-808F-E1B65E72081C}"/>
<Scope Name="VisualStudio" ID="{B465B5AD-8799-4507-B90A-EE29ACF36AF9}"/>
<Scope Name="Windows Forms Designer" ID="{BA09E2AF-9DF2-4068-B2F0-4C7E5CC19E2F}"/>
<Scope Name="VC Accelerator Editor" ID="{EB56D0B5-BEE7-4D0C-8BE6-88A8ED256695}"/>
<Scope Name="Report Designer" ID="{CB3675B8-701E-4F56-9167-2714E167FF3F}"/>
<Scope Name="Workflow Designer" ID="{D4D9FCBC-B26A-4C41-AB9F-11FD2466829A}"/>
<Scope Name="Managed Resources Editor" ID="{FEA4DCC9-3645-44CD-92E7-84B55A16465C}"/>
<Scope Name="Page Inspector" ID="{B8F809CA-7D14-4935-8657-727DC294E16B}"/>
<Scope Name="Coded UI Test Editor" ID="{E91F82D5-B532-47E9-ADAD-72F96EF9D35F}"/>
<Scope Name="Concurrency Report" ID="{5FCCFCD6-6237-4D02-B1DC-B6321AF08CE5}"/>
<Scope Name="Difference Viewer" ID="{79D52DDF-52BC-43F1-9663-B3E85CDCA912}"/>
<Scope Name="Microsoft SQL Server Data Tools, Schema Compare" ID="{00E9D2E3-9044-47D1-978C-BE2825249219}"/>
<Scope Name="Table Designer" ID="{4194FEE5-6777-419F-A5FC-47A536DF1BDB}"/>
<Scope Name="Layer Diagram" ID="{305563E9-FDF9-485B-B73E-D9FEDCC36F2E}"/>
<Scope Name="HTML Editor Design View" ID="{CB3FCFEA-03DF-11D1-81D2-00A0C91BBEE3}"/>
<Scope Name="HTML Editor Source View" ID="{CB3FCFEB-03DF-11D1-81D2-00A0C91BBEE3}"/>
<Scope Name="VC Image Editor" ID="{C0BA70ED-069E-412B-9C06-7442E28A11B9}"/>
<Scope Name="Microsoft SQL Server Data Tools, T-SQL Editor" ID="{CC5D8DF0-88F4-4BB2-9DBB-B48CEE65C30A}"/>
<Scope Name="Query Results" ID="{0058A1F7-65F3-4DB9-B3D0-CA7E64DD73CD}"/>
<Scope Name="Test Explorer" ID="{E1B7D1F8-9B3C-49B1-8F4F-BFC63A88835D}"/>
<Scope Name="XML Schema Designer" ID="{DEE6CEF9-3BCA-449A-82A6-FC757D6956FB}"/>
</ScopeDefinitions>
<DefaultShortcuts/>
<ShortcutsScheme/>
<UserShortcuts>
<RemoveShortcut Command="Edit.CommentSelection" Scope="Text Editor">Ctrl+K, Ctrl+C</RemoveShortcut>
<RemoveShortcut Command="Edit.UncommentSelection" Scope="Text Editor">Ctrl+K, Ctrl+U</RemoveShortcut>
<RemoveShortcut Command="Edit.UncommentSelection" Scope="Team Foundation Build Detail Editor">Ctrl+Shift+/</RemoveShortcut>
<RemoveShortcut Command="Tools.GoToCommandLine" Scope="Global">Ctrl+/</RemoveShortcut>
<RemoveShortcut Command="Edit.CommentSelection" Scope="Team Foundation Build Detail Editor">Ctrl+/</RemoveShortcut>
<RemoveShortcut Command="Edit.UncommentSelection" Scope="Global">Ctrl+/</RemoveShortcut>
<Shortcut Command="Edit.CommentSelection" Scope="Global">Ctrl+/</Shortcut>
<Shortcut Command="Edit.UncommentSelection" Scope="Global">Ctrl+Shift+/</Shortcut>
</UserShortcuts>
</KeyboardShortcuts>
</Category>
<Category name="Environment_FontsAndColors" Category="{1EDA5DD4-927A-43a7-810E-7FD247D0DA1D}" Package="{DA9FB551-C724-11d0-AE1F-00A0C90FFFC3}" RegisteredName="Environment_FontsAndColors" PackageName="Visual Studio Environment Package">
2</PropertyValue>
<FontsAndColors Version="2.0">
<Categories>
<Category GUID="{58E96763-1D3B-4E05-B6BA-FF7115FD0B7B}" FontName="Consolas" FontSize="12" CharSet="1" FontIsDefault="No">
<Items>
<Item Name="Plain Text" Foreground="0x00F3F2F1" Background="0x002A2822" BoldFont="No"/>
<Item Name="Selected Text" Foreground="0x00FFFFFF" Background="0x00FF9933" BoldFont="No"/>
<Item Name="Inactive Selected Text" Foreground="0x02000000" Background="0x001C1B17" BoldFont="No"/>
<Item Name="Indicator Margin" Foreground="0x02000000" Background="0x00F0F0F0" BoldFont="No"/>
</Items>
</Category>
<Category GUID="{75A05685-00A8-4DED-BAE5-E7A50BFA929A}" FontName="Consolas" FontSize="12" CharSet="1" FontIsDefault="No">
<Items>
<Item Name="MarkerFormatDefinition/HighlightedReference" Foreground="0x02000000" Background="0x00474747" BoldFont="No"/>
<Item Name="XML Doc Comment" Foreground="0x008AA399" Background="0x02000000" BoldFont="No"/>
<Item Name="XML Doc Tag" Foreground="0x00808080" Background="0x02000000" BoldFont="No"/>
<Item Name="Comment" Foreground="0x007B7466" Background="0x02000000" BoldFont="No"/>
<Item Name="Excluded Code" Foreground="0x00616161" Background="0x02000000" BoldFont="No"/>
<Item Name="Identifier" Foreground="0x02000000" Background="0x02000000" BoldFont="No"/>
<Item Name="Keyword" Foreground="0x0063C793" Background="0x02000000" BoldFont="No"/>
<Item Name="Preprocessor Keyword" Foreground="0x00BD82A0" Background="0x02000000" BoldFont="No"/>
<Item Name="Operator" Foreground="0x00B7E2E8" Background="0x02000000" BoldFont="No"/>
<Item Name="String" Foreground="0x000076EC" Background="0x02000000" BoldFont="No"/>
<Item Name="Number" Foreground="0x0022CDFF" Background="0x02000000" BoldFont="No"/>
<Item Name="outlining.collapsehintadornment" Foreground="0x00514E3E" Background="0x02000000" BoldFont="No"/>
<Item Name="outlining.verticalrule" Foreground="0x006F5C25" Background="0x02000000" BoldFont="No"/>
<Item Name="outlining.square" Foreground="0x00555555" Background="0x00E2E2E2" BoldFont="No"/>
<Item Name="urlformat" Foreground="0x00F9DA99" Background="0x02000000" BoldFont="No"/>
<Item Name="CSS Keyword" Foreground="0x0022CDFF" Background="0x02000000" BoldFont="No"/>
<Item Name="CSS Comment" Foreground="0x007B7466" Background="0x02000000" BoldFont="No"/>
<Item Name="CSS Selector" Foreground="0x00B18C67" Background="0x02000000" BoldFont="No"/>
<Item Name="CSS Property Name" Foreground="0x00B48C8C" Background="0x02000000" BoldFont="No"/>
<Item Name="CSS Property Value" Foreground="0x000076EC" Background="0x02000000" BoldFont="No"/>
<Item Name="CSS String Value" Foreground="0x000076EC" Background="0x02000000" BoldFont="No"/>
<Item Name="HTML Attribute" Foreground="0x00E4E2E0" Background="0x00343129" BoldFont="No"/>
<Item Name="HTML Attribute Value" Foreground="0x000076EC" Background="0x02000000" BoldFont="No"/>
<Item Name="HTML Comment" Foreground="0x007B7466" Background="0x02000000" BoldFont="No"/>
<Item Name="HTML Element Name" Foreground="0x0063C793" Background="0x02000000" BoldFont="No"/>
<Item Name="HTML Entity" Foreground="0x00BD82A0" Background="0x02000000" BoldFont="No"/>
<Item Name="HTML Operator" Foreground="0x00E4E2E0" Background="0x00343129" BoldFont="No"/>
<Item Name="HTML Server-Side Script" Foreground="0x00B48C8C" Background="0x02000000" BoldFont="No"/>
<Item Name="HTML Tag Delimiter" Foreground="0x02000000" Background="0x02000000" BoldFont="No"/>
<Item Name="Razor Code" Foreground="0x02000000" Background="0x003E3C32" BoldFont="No"/>
</Items>
</Category>
<Category GUID="{B36B0228-DBAD-4DB0-B9C7-2AD3E572010F}" FontName="Segoe UI" FontSize="9" CharSet="1" FontIsDefault="No">
<Items>
<Item Name="Different content" Foreground="0x000014E5" Background="0x00FFFFFF" BoldFont="No"/>
<Item Name="Identical content" Foreground="0x00000000" Background="0x00FFFFFF" BoldFont="No"/>
<Item Name="Source Only" Foreground="0x00000000" Background="0x00FFFFFF" BoldFont="No"/>
<Item Name="Target Only" Foreground="0x00000000" Background="0x00FFFFFF" BoldFont="No"/>
<Item Name="Not Downloaded" Foreground="0x00999999" Background="0x00FFFFFF" BoldFont="No"/>
<Item Name="Even Row Items" Foreground="0x00000000" Background="0x00FFFFFF" BoldFont="No"/>
<Item Name="Odd Row Items" Foreground="0x00000000" Background="0x00FFFFFF" BoldFont="No"/>
</Items>
</Category>
<Category GUID="{E0187991-B458-4F7E-8CA9-42C9A573B56C}" FontName="Consolas" FontSize="12" CharSet="1" FontIsDefault="No">
<Items>
<Item Name="XML CData Section" Foreground="0x008AA399" Background="0x02000000" BoldFont="No"/>
<Item Name="XML Comment" Foreground="0x007B7466" Background="0x02000000" BoldFont="No"/>
<Item Name="String(C# @ Verbatim)" Foreground="0x0010C2EF" Background="0x02000000" BoldFont="No"/>
<Item Name="User Types" Foreground="0x00B18C67" Background="0x02000000" BoldFont="No"/>
<Item Name="User Types(Value types)" Foreground="0x00B18C67" Background="0x02000000" BoldFont="No"/>
<Item Name="User Types(Interfaces)" Foreground="0x00B48C8C" Background="0x02000000" BoldFont="No"/>
<Item Name="User Types(Delegates)" Foreground="0x00B18C67" Background="0x02000000" BoldFont="No"/>
<Item Name="User Types(Enums)" Foreground="0x00B18C67" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Text" Foreground="0x02000000" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Delimiter" Foreground="0x02000000" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Comment" Foreground="0x007B7466" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Name" Foreground="0x0063C793" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Attribute" Foreground="0x00B18C67" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML CData Section" Foreground="0x008AA399" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Attribute Value" Foreground="0x000076EC" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Attribute Quotes" Foreground="0x00000000" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Markup Extension Class" Foreground="0x00B48C8C" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Markup Extension Parameter Name" Foreground="0x00B18C67" Background="0x02000000" BoldFont="No"/>
<Item Name="XAML Markup Extension Parameter Value" Foreground="0x000076EC" Background="0x02000000" BoldFont="No"/>
<Item Name="XML Text" Foreground="0x00FFFFFF" Background="0x02000000" BoldFont="No"/>
<Item Name="XML Delimiter" Foreground="0x02000000" Background="0x02000000" BoldFont="No"/>
<Item Name="XML Name" Foreground="0x0063C793" Background="0x02000000" BoldFont="No"/>
<Item Name="XML Attribute" Foreground="0x00B18C67" Background="0x02000000" BoldFont="No"/>
<Item Name="XML Attribute Value" Foreground="0x000076EC" Background="0x02000000" BoldFont="No"/>
<Item Name="XML Attribute Quotes" Foreground="0x02000000" Background="0x02000000" BoldFont="No"/>
</Items>
</Category>
<Category GUID="{FF349800-EA43-46C1-8C98-878E78F46501}" FontName="Consolas" FontSize="12" CharSet="1" FontIsDefault="No">
<Items>
<Item Name="Brace Matching (Rectangle)" Foreground="0x02000000" Background="0x00505050" BoldFont="No"/>
<Item Name="Current Statement" Foreground="0x00000000" Background="0x0055D1D3" BoldFont="No"/>
<Item Name="Breakpoint (Enabled)" Foreground="0x00FFFFFF" Background="0x00463A96" BoldFont="No"/>
</Items>
</Category>
</Categories>
</FontsAndColors>
</Category>
</Category>
</UserSettings>
