RepeatStringBuilderAppend the best.
//src - https://gunnarpeipman.com/csharp/string-repeat/
static string RepeatForLoop(string s, int n)
var result = s;
for (var i = 0; i < n - 1; i++)
result += s;
return result;
static string RepeatPadLeft(string s, int n)
return "".PadLeft(n, 'X').Replace("X", s);
static string RepeatReplace(string s, int n)
return new String('X', n).Replace("X", s);
static string RepeatConcat(string s, int n)
return String.Concat(Enumerable.Repeat(s, n));
static string RepeatStringBuilderInsert(string s, int n)
return new StringBuilder(s.Length * n)
.Insert(0, s, n)
.ToString();
static string RepeatStringBuilderAppend(string s, int n)
.AppendJoin(s, new string[n+1])
.ToString();
