Linux enable wifi connection on command prompt
iwconfig command is only to use only for WEP password, use it only to list the interfaces (http://superuser.com/a/353818)
for WPA2 use wpa_supplicant + wpa_passphrase instead (http://askubuntu.com/a/417498)
Guide connect to WPA2 wifi
//src - https://gist.github.com/paulborza/d5799b53ae9c8dc6d62b36a252b32795
//tested & working
//get the name of the network interface
iwconfig
//edit file /etc/network/interfaces with vi command
//edit via > press i to insert text.
//merge :
auto wlp1s0
iface wlp1s0 inet dhcp
wpa-ssid WIFI_NETWORK_NAME
wpa-psk WIFI_NETWORK_PASSWORD
//save via > press [Esc] type ZZ.
//enable connection via :
ifup -v wlp1s0
//test with ping google.com
you can find #install LXDE from commandline# at https://www.pipiscrew.com/2015/01/ubuntu-hintsntips/
#ubuntu
