Ear Candling
(video) Avoid candle - use drop of olive oil to soften the wax
(video) She is done it a job
(video) How to Clean Safely Your Ears at Home!
(video) An ancient therapy
Ear candling is an ancient therapy that's originated about 2500 BC in Egypt and China used it as a form of cleansing the ear canal. there's a wonderful way to get rid of the excess wax and to help with sinus pressure or TMJ syndrome or migraine headaches and an overgrowth of Candida in the air which is basically yeast buildup. We are going to take the candle cotton wrapped in either beeswax or paraffin wax. The method called convection which is really the heat applied to the top of the candle acts like a little mini vacuum and it sucks the pollen the yeast and moistened earwax that melts and comes up acting as a vacuum through this process travels up the candle some of it is burnt off and whatever remains as the candle burns down to the bottom. On average most ear candling treatments will last between 15-20 minutes. Candling should be done for maintenance every six months.
Olive oil
do this once a day for one or two weeks.
Wax-removing eardrops or solutions are available. These solutions often use hydrogen peroxide to soften the earwax. This allows the wax to dispel on its own.
source
Tinnitus
Sinusitis
Glue Ear
Hayfever & Rhinitus
Excessive ear wax
General hearing loss
Colds
Tension headaches
Travel sickness
Meniere’s disease
Olive oil
- Lie on your side with the affected ear facing up.
- Gently pull your outer part of your ear back and up to open your ear canal.
- Put two or three drops of olive oil in the opening of your ear.
- Gently massage the skin at the front of the entrance to your ear canal to help the oil work its way in.
- Remain on your side for 5 to 10 minutes. Wipe away any extra oil that drips from your ear when you sit up.
- Repeat in the other ear if needed.
source
Tinnitus
Sinusitis
Glue Ear
Hayfever & Rhinitus
Excessive ear wax
Colds
Tension headaches
Travel sickness
Meniere’s disease
