However, boost mode also drains the battery quicker and can bring up the device temperature. In small contained devices with poor heat exchange (like most laptops), this will spin up the fans but the temperature will also raise. A rise in processor temperature will also lead to increased temperatures in other components including the battery.
Disable boost mode and sacrifices some peak performance in exchange for a cooler laptop and prolonged battery life.
The temperature change you’ll see by disabling boost mode will vary based on your environment, hardware, and usage pattern. His MacBook Pro dropped the average battery temperature from 41℃ to 32℃ after disabling boost mode. It also runs quieter and the battery last about 30 % longer on a charge.
Execute
this will make visible the option Performance Boost Mode under Processor power management
from there set the OnBattery & Pluggedin to disabled. No restart needed.
src - https://www.ctrl.blog/entry/laptop-boost-mode-battery.html
src
Many other factors can affect device temperatures. Poor ventilation is a primary cause of hot laptops. You can improve the ventilation by applying floor protectors to the bottom of your laptop to create more clearing between it and the table. There’s absolutely no need to buy an expensive cooling stand for your laptop.
The instructions are super simple:
1-Pick up some thick, round, and medium-sized felt pads or anti-slip pads
2-Cut one pad along the middle using scissors
3-Glue one half on either side with the round end pointing backward and the straight edge facing forward on the underside of your the laptop towards the back (pictured below)
This will lift the laptop slightly higher off the resting surface on the table. This will allow for heat exhausted from the laptop to dissipate faster due to the increased space making room for more air circulation. It’s an easy way to improve laptop cooling.
src - https://www.ctrl.blog/entry/how-to-laptop-air-cooling-pads.html
ref
https://www.amazon.co.uk/s?k=floor+protector+felt+pads
https://www.amazon.co.uk/s?k=floor+protector+anti-slip+pads
Execute
powercfg.exe -attributes sub_processor perfboostmode -attrib_hide
If you have enabled virtualization in your BIOS or UEFI settings, then Processor power management will not be available, even if you set them to be added.
Only when virtualization is disabled in BIOS/UEFI will be shown
src
ref
